Bank of America
Last activity: 25 Jul 2019 10:53 EDT
How do we determine if a property is optimized or not?
We index and exposed embedded properties as columns. How do we determine if any property is optimized or not.
Is there any way in dev studio where we check given a property if it is optimized or not.
Hi Shruti,
Thanks for posting the query.
You can use the modify schema wizard to check the optimized properties.
1. Go to the Designer-studio-->System-->Database-->Modify Schema.
2. Select the database where your work table is present.
3. Select the work table that got mapped to corresponding work class.
4. Click on the columns link inside the grid to view the properties.
5. The properties which were already exposed will be greyed-out.
