Security Audit is not working for delete instance
Through Security Audit feature ,No instance is getting recorded in history table when deletion of the data instance . Upon deletion of the data instance the trigger activity (TrackSecurityChanges) is getting invoked using declare trigger .
As per observation : "pyChangeTrackingMemos" are not getting generated from TrackSecurityChangesLogic activity when instance is deleted so there is no entry in history table for deletion operation .
I see, the similar issue has been reported by other techie as well.
