Stella
Last activity: 20 Jun 2019 18:29 EDT
Copying attachments from one work object to another
I have an activity to copy attachments from one work object to another. It works when I run it standalone but when I run it from an SLA it does not work. There doesnt seem to be any errors and I am able to trace it through the SLA agent. I'm wondering if anyone can tell me what I might be missing.
Activity is showed in attachment. First step is not showed as it is commented out anyways.
FR
Could you share your tracer output as well? Any error on the log files?
Stella
Sure. I'll generated trace. I'm having trouble with the logs. Only way I can access the logs is through kibana for util node and I am unsure if I am using it right. It doesn't look like there is anything there if I am using it right.
Stella
Tracer
7zip
FR
Well you do have an error from the very beginning of the execution. The SLA instance right after the open is having a pzStatus set to false. I don't think you will have that if you run it manually but please double check.
Stella
I have an error at the beginning of tracer you mean? I'll double check
Kaiwalya Pardeshi
Stella
I reran. I don't see any red in tracer. I'm not sure I understand
Stella
I pulled a stupid. I figured it out. I didn't had the wrong page
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-07/f7f35052-5e7d-4ed9-ada9-87594f1d3c63.png?itok=bz3Ms_gZ)
So glad to hear that you resolved this. Could you share your resolution as it may help others in the future?
Stella
Well I thought this was working but I'm having a problem I discovered. When I try to open the attachments on the target work object the files associated with the attachments are empty.
