Amazon
Copy directory from one location to another location
Hi
I am trying copy a folder which has sub-folders inside it from one location to another location on the same server. I am using the below Java code to iterate through the files in the sourceDir and copy it in teh DestDIr. However, it is deleting the source directory, meaning, it is not copying but moving. It is moving the directory only if the directory has files and doesnt have sub-folders.
Is there any method I can use;
1. To copy the sub-folders as well (I tried using copyFolder method of Java 'File', but not working in Pega. Is there any equivalent method?)
2. To copy the files (If 1 is not available withing Pega, i can recursively loop through the folders and achieve 1 using 2)
for (int i = 0; i < listOfFiles.length; i++) {
if (listOfFiles[i].isFile()) {
java.io.File afile =new java.io.File(SourceDir + listOfFiles[i].getName());
afile.renameTo(new java.io.File (DestDir + listOfFiles[i].getName()));
Thank you!
