VM for 7.3, 7.4 - Lighter Version that uses less memory
Is there a new VM available for 7.3, 7.4 app build that uses less memory? It was mentioned on the CLSA roundtable meeting
Yes, it is the Linux Lite VM and it can be downloaded from Pega BOX using the following link:
https://pega.app.box.com/v/llvm-lsa731
Hi Henry,
This link is not reachable now, do you have any other URL where I can download this VM ?.
Vinay
I just downloaded and am running it -- this is awesome! thanks so much. Just to confirm, this is the VM that we should use for the 7.3,7.4 LSA app build.
You can use any type of VM , CentOS, Linux Lite, Lubuntu, or PE you want to develop your solution as long as PegaRULES 7.3.1 is installed in the database. A R-A-P is a R-A-P.
