Tech Mahindra
Last activity: 25 Mar 2020 1:51 EDT
Is there a way to hide Agile Workbench on Case manager portal for particular acceess role
Is there a way to hide Agile Workbench on Case manager portal for particular acceess role.
Likes (1)
Istvan Szepkuti -
You can set access as desired for these privileges:
- pxAgileWorkbench
- pxAgileWorkbenchItemModify
- pxAgileWorkbenchItemReadOnly
The manager role for my test application had pxAgileWorkbenchItemModify and pxAgileWorkbenchItemReadOnly specified for the classes below. I set the access to 0 and the Agile Workbench bar no longer appeared.
- Pega-Agile-Work-Bug
- Pega-Agile-Work-Feedback
- Pega-Agile-Work-UserStory
On my 7.4 system, I see it is based on a pyEnableAgileWorkbench when condition so you can check the when rule for the conditions. I see there are a few privileges checked so you can review those and add/remove them to the desired access roles.
Sorry, I was looking at Designer Studio. I will check my Case Manager portal also.
- pxAgileWorkbench
Meena Subramanian Istvan Szepkuti
Tech Mahindra
Hi Carissa,
I updated my role with those privileges like you suggested but still am getting Agile workbench as a movable control on bottom of the left nav.
Srinivas
Tech Mahindra
The solution you provided is worked for me.
Thank you.
Hexaware Technologies Ltd
Could you please add the step by step procedure screenshot. So that it will be easy for us to fix.
Early response will be great.
Sornalatha R
Coforge Ltd
You can simply modify the OOTB when rule "pyEnableAgileWorkbench" according to your requirement .
Example: Add one more AND condition to the existing when rule logic.
pxRequestor.OperatorID.pyAccessGroup != "Your accessgroup name"
Update pages and classes tab as below:
Page name: pxRequestor.OperatorID class:Code-Pega-Requestor
SORNALATHA R Steve Youles Tom Zhang Aditya Kumar Gupta Kiranmai Bhavani and 3 More
Thank you. I got the solution and it was helpful
Sornalatha R
