Chevrons are not displaying while adding UI-Kit7:10-01 In Application Definition.
1. When I add UIKit (10.01) in Application Definition Chevrons(Stages) are disappearing. Up to my understanding value is not passing to ShowStageCompletion Parameter in pyDisplayStages section, so visibility condition failing , chevrons are not appearing.
2. When I remove UIKit from App Definition , then pyDisplayStages section is calling from pepa-EndUserUI (7-10-25) is calling and Chevrons are displaying.
3. I am using Pega 7.3.1.
4. If I remove UIKit, I can't use latest UI controls.Its causing more issues.
So please give me solution without removing UIKit from Application Definition.
Thanks & Regards,
Savitha
