AGL
Last activity: 24 Mar 2019 21:01 EDT
RealTime DataFlow Service Call
Hello ,
I saw a post the reply to below post
In the above post, it was suggested to use the service in the data set to call from a service. But When you create a data set, the stream has an ip associated to it which is the node you log in. I have two questions.
1. Can we have an alias here instead of an IP as the nodes keep changing.
2. When this same data set is used multiple realtime data flows how does the service invoking take place? Does it invoke all data flows?
Thanks much
Pradyumna
