Check Harness Type
I have a requirement to display a layout in review harness and hide the same in perform harness. Which property do I need to check for the Harness type ?
we have when rule called pyIsHarnessTypePerform
Please use the above when rule show and hide the table layout
Please comment if it works
Why do you need to check the harness type? Just make it visible on REVIEW harness and invisible on PERFORM harness.
Those are two different rules anyway.
Can you try using "!pyIsHarnessTypePerform" in the visibility when condition of the layout?
