Lloyds Banking Group PLC
Last activity: 11 Apr 2019 6:17 EDT
Unit testing a decision table
v7.3.1
Created a unit test case for a decision table and added multiple inputs to test against all possible combinations of input and return.
Updated this decision table in a later version to include a new column, however when I open/save as the original test case to update it with scenarios, the new column is not reflected in the test case rule.
So I had to end up again manually copying the different scenarios across to a new test case. Is this the expected behaviour with this version or is this a bug?
Another question I have is - what is the best practice in terms of the rule set created for unit tests. Should they be locked at the end of each sprint and a new version created or can they be left open?
