Last activity: 21 Feb 2019 10:27 EST
Pega Selenium Starter kid - getting error while running from Command Promt/jenkins
Hi team,
We have configured Selenium Starter kit and able to run successfully from Eclipse IDE.
But getting below error message while running through Command Line -
Error Message - "dependencies.dependency.systemPath' for com.pega.test:pega-base-ui-testframework:jar should not point at files within the project directory"
And Also getting the below error message while running through Jenkins -
Error Message - "Plugin org.codehaus.mojo:build-helper-maven-plugin:1.1 or one of its dependencies could not be resolved: Failed to read artifact descriptor for org.codehaus.mojo:build-helper-maven-plugin:jar:1.1: Could not transfer artifact org.codehaus.mojo:build-helper-maven-plugin:pom:1.1 from/to central (https://repo.maven.apache.org/maven2): Connect to repo.maven.apache.org:443"
Please help us to resolve these issue.
Note - we are following the exact steps mentioned in "Selenium Starter Kit - Running Tests" and "Selenium Starter Kit - Running Tests in CI_CD" both guidelines.
Thanks for looking in advance.
