CapGemini
Last activity: 16 Apr 2019 8:53 EDT
Client needed Select all/Un select all fucntionality in filters for all reports instead of clear filters .
Hello Guys..
-------Client needed Select all/Un select all fucntionality in filters for all reports instead of clear filters -----
Client need to Use filter option available at each column in reports to select and unselect all values(Same as like in MS Excel) , so that Use filter option available at each column in reports to select and unselect all values(Same as like in MS Excel) . User can manage filters appropriately.
Hi Chandrababu,
This feature is not available OOTB and the rule which is being used for this popup is pzGridFilterPanel which can't be modified. You can go though this discussion over here. If you have customized the display then you can probably use a data transform to enable pySelected for all the rows as specified in Kip shared post in the above discussion.
Mahesh M
