Celfocus - Soluções Informáticas Para Telecomunicações SA
PT
Last activity: 19 Feb 2019 11:28 EST
How to get all the elements of a page list in data transform?
I need to get all the elements of a page list using a data transform.
I'm getting the data from a SOAP connector, please find below the example of the xml with the field that I need to map:
<ns0:CharacteristicsValue characteristicName="Model" xmlns:ns0=".../schema/common/v1">
<ns0:Value>GSM</ns0:Value>
</ns0:CharacteristicsValue>
<ns0:CharacteristicsValue characteristicName="Hidden" xmlns:ns0=".../schema/common/v1">
<ns0:Value>N</ns0:Value>
<ns0:CharacteristicsValue characteristicName="AttributeName" xmlns:ns0=".../schema/common/v1">
<ns0:Value>Social</ns0:Value>
How can I get these elements using a data transform?
Thank you.
Have you already used a Parse XML rule to parse the data into properties? If not, the below article has some information that may help:
https://community.pega.com/sites/default/files/help_v81/procomhelpmain.htm#rule-/rule-parse-/rule-parse-xml/mapping.htm
If you've done that already, can you please elaborate a little on the properties you've put the SOAP response data into, and what you're hoping to do with them via the data transform?
-Kurt
