Links
Last activity: 19 Feb 2019 11:57 EST
Authentication and Authorisation with Pega Mashup
Hi team,
I am new with Pega mashup and trying to understand the architecture design to integrate with the currently existing site which is designed in Angular 2 platform.
I have gone though couple of links, but doesn't make things very clear. Would you be able to provide
information on how should I begin with on the following requirements :
1) Authentication and authorisation of the users. Now, the current application does not support SSO, so what should be the other solution to support Authorisation and authentication.
2) in which format the data is received from Pega, which can be further parsed to embed in application.
Could you please provide step by step procedure to achieve this task.
Deeksha
Links
Thanks for the information!
The question has been answered.
Hi Deeksha,
To start with Pega Mashup, you can go through following tutorial:
https://community.pega.com/knowledgebase/articles/tutorial-creating-mashup-pega-web-mashup
Links
Thanks Arvind !
This has nearly answered my query, but I am speculating how can I apply user Authentication with Pega systems. The current system does not support SSO management, the what other design could be used to integrate with Form based authorization.
Are you looking for PRPC SSO or SSO for Mashup only?
Links
If you could provide me all possible ways to authenticate user with Pega Mashup. As I have to build the solution from scratch, I need a detailed way from where I can begin the development for user authentication with SSO management.
Links
I need to begin with User Authentication, so please give me details of how to begin development on this.
What are the pre-requisites of the system to connect with Pega Mashup. Should I do any configuration for the user to connect with Pega mashup. Is there any service URL that authenticates users.
Hi Deeksha,
For SSO implementation, I suggest you go through this article:
Links
Hi @DeekshaK!
We'd love it if you could share your resolution here so that it may help others who have the same question.
Thanks!
