EY
Last activity: 17 Jan 2019 18:07 EST
Logoff from an activity
Dear All
I have a requirement to call the pega standard logoff activity from my activity based on a condition. The standard logoff activity is running fine, but it's not redirecting to login screen. Only on reload of page I see the login screen. Can somebody advice what needs to be done to achieve the functionality
You should review OOTB Code-Security.Logoff activity and customize the HTML Web-Redirect
EY
can you please let me know what to change in Wed-Redirect
FR
Why don't you just customize Logoff activity? It isn't FINAL. Or just use the extension activity called pyLoadSamlSsoLoginInfo
EY
It's not final. I am not sure where to make the changes.
Hi Babu,
Please go through the suggestion made in the last comment in this discussion and give a try to implement your requirement. Hope that might help you.
Regards
Mahesh M
EY
I tried that mahesh
It's logging off but not redirecting to login screen
Hi Babu,
If you have any chance of creating the logoff functionality on click of button or link, then you can probably look into the use case created by me in attachment. If your requirement is specific to your activity, then may be you can try to remote trace and see what happens during logoff functionality OOTB.
Regards
Mahesh M
Eric BENARD Imane Astaifi
EY
Thanks Mahesh
But, logoff functionality is working on button click. Even I have few scenarios where I am using like that. but my requirement is to call the logoff activity from another activity.
