Data page loaded when "obj-open" a work object
In our application, a property is defined on the work class. This property refers a data page and this data page use a connector REST.
For a business requirement, we need to open a case with "Obj-Open-By-Handle" method to read another property.
When we use this method, the data page is loaded... And we don't want this behavior because the business requirement is to read other property; and the data page execution slows the application because it's a connector.
I think it's not correct behavior because the data page should be loaded only when the referred property is used declaratively.
I have compared this property with the OOTB property ".pyAttachments" which referred the data page "D_AttachmentList". We can observe that this data page is not loaded until the property .pyAttachments is used.
I have attached word document with complete description.
What do you think about this behavior ?
We have created the SR-C72699 about this behavior but this SR is currently closed.
