Ford Motor Private Ltd
Last activity: 23 Jan 2019 21:33 EST
Connecting ODBC through MS Access
I have a SQL Query already designed in MS Access which extracts data from ODBC Connection through authentication. While i execute the query using OLEDB Execute Query the automation is starting but not getting executed. Authentication pop up window also is not coming up which is coming while is test the query in properties pane. Need support to execute the query and download the datatable onto an excel file.
