ING
Last activity: 13 Sep 2018 12:25 EDT
Unable to connect to the MSAccess accdb file using the ODBC component
I am unable to connect to the MSAccess accdb file using the ODBC component. I have given the query string as "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=C:\Program Files (x86)\OpenSpan\Payroll.accdb;"
After giving the connection string and do test connection I get the error that "Test connection failed because of an error in initializing provider. Unspecified error"
Can any one help me please
Do you have Microsoft Access ODBC driver installed? You should see it available in "ODBC Data Sources" dialog:
If not then you probably need this: https://www.microsoft.com/en-us/download/details.aspx?id=13255
