Ernst & Young LLP
Last activity: 29 Nov 2019 2:13 EST
Agent is throwing NullPointerException when calling pxCallRetrieveReportData from agent activity
Requirement: I have to generate a report from agent activity.
Issue: When calling pxCallRetrieveReportData from agent it is throwing NullPointerException.If I am running the activity stand alone its working fine. Tried with Rule-Obj-Report-Definition.pxRetrieveReportData . But it is not working.
FR
Can you verify if the AccessGroup associated with your Agent requestor does have the required access for said activity.
Ernst & Young LLP
Hi Marc,
Thanks for your input.
I tried both of the options.
1.Without access group
2. With Administrator access group.
But none of the options are working.
Ernst & Young LLP
Just another point.
The agent activity is working fine if I am commenting the step of calling pxCallRetrieveReportData / Rule-Obj-Report-Definition.pxRetrieveReportData
FR
Actually,
Can you work with RunReport activity instead on your Agent. I wouldn't recommend to work pxRetrieveReportData directly.
Kensho Tsuchihashi SRIKANTH YERMANI
Ernst & Young LLP
Hi Marc,
Sorry. I didn't understand the point clearly. Are you suggesting me to leave the Agent approach?
Edgar Iván Vega López
FR
No, of course not. I was just wondering if you could change the activity to use RunReport instead.
Can you please check the below article
Can you please try to save all the activity in the same class with the same ruleset. Agent usually will not be able to find the activities because of rule resolution.
