areteans technology solutions pvt ltd
Last activity: 27 Dec 2018 16:30 EST
Pega integration with RDA
Hi Team,
i am currently integrate pega with rda.whenever i start my bot in my local system its working fine.
http:// Proprietary information hidden:1030/prweb/api/v1/.the same thing i need trigger my bot from other system its doen trigger the bot.bot is installed other system and pega local url in another system.
There is not enough information here to advise you on this. Could you share a RuntimeLog.txt capturing this issue? Are you able to reach that address manually from the machine where this fails? When you say that the bot does not trigger, is the solution loaded? Are there any errors you are experiencing on the screen?
Please provide more detail pertaining to the issue you are experiencing.
