Instellars
SG
Last activity: 30 Nov 2018 4:28 EST
How to Populate the table Data in User Interface
Here I am trying to populate the table data in User Interface but I am not getting the data in User Interface. Already I selected repeating layout and updated source as a data page.
See below screenshots for your reference.
Please help in this..
Prasad Rangu
EvonSys India Pvt Ltd
It's problem with your UI(Repeating Dynamic Layout expects Section). If your expecting data table data to be in a table grid format just make a change as Table instead of Repeating Dynamic Layout and as a best practice make datapage source as default existed DataTableEditorReport to fetch the entire data table list.
Hope this helps.
Mastek
Hi
Looking at the configurations I doubt your data page is getting populated. Can you confirm that your data page has values when the screen gets loaded and also by running it standalone.
Regards
Bhavya
Avinash Haridasu Mourad Meddeb Isuru Dananjaya
Instellars
SG
Hi Bhavya,
Thanks for the reply and here i am sharing execution results of Data page.
I think no problem with the data page it is working fine.
How to fetch the table columns in table grid layout could you please show me with example.
Prasad R
Mastek
Hi
There are two issues here.
1. You data page is not getting populated here. If the data page is Source, then it should have pxresults. So you need to copy the data from User Page you have in your acitivity to data page or use Report definition as a Source
2. As Surya mentioned, your UI is wrong. You need to use Table or a grid as below:
Regards
Bhavya
Hi Prasad, Your Repeated Dynamic Layout(RDL) is configure correctly but the issue is that you are having a section inside of it where it says "<<Drop a single section>>"
You need to create a section with needed properties from the datapage and include that section into your RDL.
Also as mentioned by Bhavya you need the results in the datapage under pxresults pagelist to get the right results.
Hope it helps!
Joseph Azar dany aoun Rayan Al Hassanieh Luna Tello Elie Rahal
Hope this helps.
Instellars
SG
Thanks it is working fine now
Karimulla Nallaemambugari Mert Çaldağ
