JP
Last activity: 30 Nov 2018 1:48 EST
Unable to open a work object
For some reason, at some point this incorrect behavior started but I can't find what is actually causing issue.
In my application, I have WorkType1 as a class group under MyCo-MyApp-Work. I mapped MyCo-MyApp-Work to PC_WORK table as we would never instantiate at this level but always child classes will be used for instantiation. Hence MyCo-MyApp-Work-WorkType1 is a concrete class and class group (=Workpool).
I have not done any customization around Security (ex. Access When, Privilege, etc). My developer access group ("MyApp:Administrator) inherits from PegaRULES:SysAdm4 (I use Pega 7.4) and it has all access in Work- as 5. So, I should be able to open a work object W-1 without any problem. However, when I simply try to open W-1, I get an error on screen saying, Unable to open an instance using the given inputs: MYCO-MyAPP-WORK W-1.
I don't know why Pega is getting this wrong handle name - It has to be MYCO-MYAPP-WORK-WORKTYPE1 W-1. As a matter of fact, when I private edit one of an activity @baseclass.doUIAction to set this correct class as pzInsKey, it works. I gave a try and error like setting my access group to MyCo-MyApp-Work-WorkType1 as a Workpool, resave class group, delete Marker file and restart, but none of my trial is working.
Anyone has any idea how to get this to work?
Which database are you using? Can you check on the database side? How is you key there?
