Inserting huge data into Pega DB
How to insert data into DB without using the UI route ? The application we test consists of around 20 pages with numerous fields that makes downstream data flow testing a tedious process. Is there a solution where we can insert data directly into 60 odd tables directly instead of using Application UI ?
Hi Biju,
Would request to use BIX to extract the data into other tables which can be done either done through command line or Designer studio. Please let me know if this clears your query.
