What should be the first control you interrogate?
I am in a similar situation as stated in this post: Text Adapter
Wondering what the first control you interrogate is. I have attached a screenshot showing where I am confused. It could either be Screen or Match Region.
When interrogating an object, you should first set up a match region for the screen. This will create a screen which the additional controls will be placed on. For a match region many times there is a screen name or number displayed on the screen that is unique for the system. I use that whenever possible. You may add multiple match regions to a screen as needed to make your match unique in case there is not a single unique identified.
