Need to know the definition of this OOTB function/script rule: "selectThisProp", as it needs to be called explicitly in a scenario where its not executing OOTB
Need to know the definition of this OOTB function/script rule: "selectThisProp" which is present in OOTB Section (screenshot attached), as it needs to be called explicitly in a scenario where its not executing OOTB.
Name of the OOTB Section Rule: "PropositionRow"
Class: PegaComm-NBAMCFW-SR-Negotiation
RS- PegaNBAAC-Rules:07-22-01.
The script mentioned above Runs on Click of the Select / Add Button in the above section rule (screenshot attached).
As the Script is not getting executed in such a scenario, we may have to write a function / script based upon the definition of this script.
