Where should I specify Access Deny rule?
I know we can specify Access When rule in ARO.
It seems any string (not number) is associated with Access When. Is that correct? If that is the case, where can I specify Access Deny? Not in ARO instance?
Have you looked into HELP file. This might help for example: https://community.pega.com/sites/default/files/help_v74/express/procomhelpmain.htm#rule-/rule-access-/rule-access-deny-/rule-access-deny-obj/main.htm
