Chevron
Last activity: 10 Aug 2018 6:47 EDT
Create grid line items/ table in pega 7.3.1
I've been trying to create a shipment request form where the shipper can input multiple items. There are 8 columns of the shipment details. I cannot figure out how to get it functioning right. I already created a data object and am able to drag over the page list fields into the layout but it shows up as blank.
I have already viewed many instructions on how to create the gridline items on pega academy but the instructions seem to be outdated.
I get the feeling I'm creating the wrong layout or dragging in the wrong place.
Any help would be greatly appreciated, I've been working on this for quite sometime.
Thank you,
Tata Consultancy Services
The error says your are using pagelist so you need to mention subscript EX(ShipmentDetails(1).pyLable) in your DT.
you can use For each page in and set your values.
Could you please provide the snapshots of your configurations as well as your sample wireframes.
Chevron
Thank you for the reply, I would be happy to provide you with this information. However, I don't know where it's located.
Could you elaborate please?
Chevron
This may be my main issue, I tried to add initialization per the instructions in pega academy. However, I get this error.
I found that I can remedy this by switch it to page instead but then it doesn't allow me to use it in a table layout in my section if it is a page type.
I am having trouble implementing exercises shown on pega academy because they are so outdated and don't match up with the UI I am using. If I could be given sources to a detailed and up to date guide on how to create a form that allows the user to add multiple items like in a table or grid I would be grateful.
Thank you,
Chevron
Sorry, here is the attached error
Jenish Jerome Sanjoy Bhattacharyya satsih chitturi
Chevron
Thank you, I think I was able to get it figured out thanks to your guidance.
wc :)
Please revert back to me if you need more clarification.
Chevron
Here is the configuration for the layout I attempted.
