Cognizant
PH
At least one 'scriptName' method must be added after upgrade
We upgraded from OpenSpan 7.1.79 to PEGA 8.0.1096, now the issue below on script is encountered. It says At least one 'scriptName' method must be added. There is already a method added to the script (see attached genGC.scriptFileHelperCopyCutFile.txt)
What am I missing from the upgrade? Im using Visual Studio Community Edition and PEGA 8.0.1096 Plugin.
Thanks in advance.
Cognizant
PH
Hi It seems that the pega studio on my machine is causing the deletion of methods. I'm 32 bit. Migrating using PEGA plugin running in a 64 bit machine fix my issue. Thanks.
I'm attaching a text file of how the .os file for your global container should look with the script that you attached above. Pay close attention to the lines for the Openspan.Script.Custom.Script tags, as this is where your methods are outlined. If your .os file does not look the same, or very similar, then there is likely an issue, either with the upgrade or with the product.
Alternatively, it may be possible to fix your issue by copying the missing lines into your .os, saving the file and reloading your solution.
You may also attach your .os file to this thread if you would like help inspecting it.
S MANOJ KUMAR REDDY
Cognizant
PH
My openspan.script.custom.script doesn't have items inside it. Can I edit this manually?
Cognizant
PH
Hi I tried editing it manually, and I noticed that the content inside the Openspan.Script.Custom.Script is being deleted everytime the solution is build.
Please open a Support Request. This issue will need to be investigated in more detail.
When you open the SR please reply back here with the ID so that we may track for you.
Thank you!
Cognizant
PH
SR is opened by our vendor.
Request# SR-C44104
Cognizant
PH
How to create SR for this? Thanks.
Cognizant
PH
