Accenture LLP
RPA: Creating a bot to test if all interrogated components are available
Hi there,
Can i create a bot to test if all interrogated components are available ? Ex- i have interrogated 5 objects and i need to know if all those 5 objects exists. In that if 2 objects fails, bot should navigate to find if 3 object is available or not and then 4 and 5. Right now, i created a Unit Test Bot but the problem is the bot stops if any of the object is not found and exits the flow. i would like the bot to continue finding all the objects used in the main automation. Please help to solve the issue.
Rajesh Anand
