Wells Fargo
Last activity: 21 Jun 2018 10:21 EDT
Field Level Auditing for Data Classes
Hi Guys,
What is the best way to implement field level auditing for Data Classes.
Business wants to capture Audit for every operation that user performs, for instance "User XYZ changed the value of Owner Fax to 321-324-2123 from 321-706-4543" and so on.
Pega OOTB Field Level Auditing works only for Work Classes. We don't have any work object associated with these data objects. They are primarily data grids and edit screens without any process flow- where user can edit any object or create or delete one.
1. Would Declare Trigger be a good approach? There are going to be lot of end users in production that might be editing information on different objects at the same time and updating the Audit table. Could this lead to Performance issue?
2. Also, if declarative rules are used- is there a way to track which properties got changed-because of which it was fired?
3. Should the existing Pega History tables be used for Audit or separate table should be created?
Thanks much!
Bhagyashree
