Object Inspector issue
Not able to find the Method, Event and Properties icon under Object Inspector.
May be that window is in lower window. Try by dragging upside.
Keep mouse on line above No selection and drag up side as shown in attachment.
Hello Nitin,
Just provide a screen shot of your issue for our better understading. Hope you need to click the button towards the right corner
If this doesn't work, provide screen shot and robotic version used at your end.
Hari
Thanks a lot, dragging upside down did the trick.. thanks a lot again..
Thanks Jayachandrak!
