Avanade
Last activity: 2 Jul 2018 14:04 EDT
Adding Multiple Scripts
I have one solution, with 3 different projects where i'm trying to add a script in each project that accomplishes the same task (exact same code). I can create the script in the first automation, validate it, and run it just fine. but when i try to create the script in the second automation, it says it validates successfully, but the method i'm creating never shows up in the method section of the scripts properties window. is this a bug or something i am doing wrong?
I've attached pictures showing that the script is indeed validated and another picture where i even open the properties to show the method isn't there/can't be added
