PDF download not working
We are trying to download pdf files using Code-Pega-PDF.View activity (OOTB), but it's not working when it's called from a modal outside case (without errors on trace or log files).
This activity has only one step with this script:
//Get the byte array from the parameter page
byte[] byteArray=(byte[])tools.getParameterPage().getParameterValue("PDFDocument");
//Get the pdf name from the parameter page
String pdfName=tools.getParamValue("PDFName");
//Send the PDF File back to the user.
String result=tools.sendFile(byteArray,pdfName,false,null,true);
Both parameters are correct and filled when running this step. Before open modal, we open a work object using Obj-Open-By-Handle by .pzInstKey and OpenPortal/$WorkProcessing thread is created. Does anyone used this activity in similar situation or know any solution about this issue?
Any help would be highly appreciated.
Yuri Silva
