Water NSW
Last activity: 18 Aug 2018 4:22 EDT
Looking for Archival strategies/solutions implemented for Pega Applications
Hi Everyone,
As Pega has limited set of functionality for archiving and purging the case data through Archive and Purge Wizard, considering the basic functionality provided with this OOTB functionality, would like to know how various organisations are implementing/handling the archival & purging of case data and methods to access the archived data.
So, if you are aware/worked of any such implementations, can i request you to please outline the solutions that is implemented in your organisation/projects.
This information collected from various projects can be used to create a standard/recommended pega case archival solution, which can be cost effective and user friendly. We can also use this to request pega to come up with a feature or as an enhancement.
If it is already in place/documented would you be able to share the details here.
Thanks in advance.
