Access files from SFTP server
I want to access files for my automation process from SFTP server. How we can connect to the server through Pega Robotics to access the files?
You need to interrogate some application or write some code to do this. There is no built-in component for accessing an SFTP site. If you can access it through Internet Explorer, then you can probably automate it via the web adapter.
Here's an article explaining how to use the download bar if you download the files via IE.
https://collaborate.pega.com/discussion/automating-ie-download-bar
