Tech Mahindra
Last activity: 22 May 2018 21:38 EDT
Declare page vs Data Pages
In Upgrade project 6.3 to 7.3. Can we use the declare in PEGA 7.3? in our application, there are many pages populated(static data) from data table under one declare page and that are being used entire application so how can we use this same declare page in pega7? is this feasible? If yes, is this pega best practice to continue to use this declare pages in 7 version? or shall we go for data pages? again If yes , then we should again change the entire code where we are referring the d pages. Is there any easy way around to use data pages without code changes which has been made from data table to data type conversion and to create the data page?
Got error message "Java Exception: java.lang.UnsupportedOperationException:" if try to use the same declare page by using the RD of data type.
Please suggest.
