com.pega.pegarules.pub.clipboard.InvalidReferenceException
I've been asked to investigation errors that are occuring in our production environment since our upgrade from 7.2 to 7.31.
There are a lot of errors occurring daily with the title of this posting. Specifically this is the full error message :-
Caused by: com.pega.pegarules.pub.clipboard.InvalidReferenceException: The reference .pyWorkBasket is not valid. Reason: .pyWorkBasket is mapped to class Data-Admin-WorkBasket, which is not the primary class of the list: Data-Admin-Workbasket; must specify a group name in mapping
Seems to relate to a report definition from a datapage. Previous error to the one above is :-
Caused by: java.lang.RuntimeException: caught exception while expanding property pxResults on page D_WorkBasketsInWorkGroup_pa4357572887357862pz
This datapage is used to drive a dropdown component. The datapage is Structure = List , Object type = Data-Admin-Workbasket, Edit mode = Editable and Scope = Thread. Datasource is a report definition against class Data-Admin-WorkBasket. The report returns pyWorkBasket, pyWorkGroup and pyLabel. The dropdown component then uses .pyWorkBasket for the "Property for value" field and .pyLabel for the "Property for display text".
Only reference to this error I have found is https://pdn.pega.com/support-articles/tab-switching-does-not-work-after-passivation but this refers to Pega 7.2.2.
Any ideas?
Craig
