Work Object Already Open
We have a UI for some delegated rules which end user is able to change. The UI is working as expected, the problem is when we click twice on the menu item. The second time popups a message saying the "Work Object Already Open. Would you like to reopen the item and lose any unsaved changes?". The problem is that this is not a Work Object and this message does not seem quite correct. We are using the pzDelegatedRules Harness OOTB and the intent is to avoid customization.
Is there any workaround to avoid popup this message?
P.S: Opened an SR, but was recommended to post my question here in the support community. SR-C30860
Can you open the action configuration of the menu item link and check if there is a double-click action associated with it? If yes, remove it and only have a single click.
