Datacom group
NZ
Last activity: 29 Oct 2019 9:36 EDT
Robotics Test Harness
Hey All,
I have downloaded the Robotics Test Harness DLL from from the attached file and has referred it,
and tried to open up the TestHarness for testing purposes. I could open it up using the ShowTestHarness method. But I was wondering what would be the best practice to open this harness in a development project. I want to know how to invoke the Harness and the place(ie: beginning of the main flow)
***Moderator Edit-Vidyaranjan: Removed Box url and updated content***
I generally invoke it off of the RuntimeHost.AllProjectsStarted event. If you want to keep it out of your main project, create a separate solution/project that references your main project. This "test" project would be the startup project and would only reference your main project. Since this is a separate project/solution, you would be unable to accidentally release it since your project has no knowledge of it.
Accenture
hi ,
after adding the test hardness Show method . i am getting an Error and not able to build the solution.
Err Msg:- Severity Code Description Project File Line Suppression State Error Could not resolve type OSComponents.Utilities.TestHarness.TestHarness.
please help me on this
Cognizant Technology Solutions India PVT Ltd
It is asking for password , Can you please share the password for same
Prime Therapeutics
"openspan" took me 5 tries :)
CollabPartnerz
Please find the below post might help you
Updated: 12 Sep 2019 5:36 EDT
Tech Mahindra
Download the DLL file from attachment.
Unzip with password - openspan
How to import the DLL file into your application - Check the webiner 'Importing custom DLL files' in 'Pega Robotic Automation Advanced Topics' Training material.
Have fun :)
RPA/RDA Practitioner
Steps to add TestHarness: See attached image
The test harness attached no longer works in 19.1. In 19.1.14, that functionality was released within the product. It is now called Robot Inspector.
https://community.pega.com/knowledgebase/documents/using-robot-inspector
