Last activity: 20 Jun 2019 1:50 EDT
how to select multiple values in dropdown
Hi, I have a property called offername and a dropdown called offers. Offers dropdown should show all the offers but the user should be able to select more than 1 offer in the drop down. I am 4 months pega employee so i would really appreciate it if you can explain it in very simple steps. I am using pega 7.3.1
I am attaching a screenshot which shows how i want the screen to look like.
thanks
Maantic
Refer below attached document.
Please check below link:
https://collaborate.pega.com/question/want-have-multi-select-dropdown-values-how-do
Susan
Hi satrs,
Use "Launch -> Local action" to launch a local action in overlay and inside the overlay configure a repeating dynamic layout with pagelist / data page. The section included in the repeating dynamic layout should hold 2 things,
1) a check box property to capture multiple selection
2) value of the selected item.
How to capture the selection ?
Configure "Post Value" and "Run Activity" actions on the checkbox control. The activity will basically accumulate the selected entries and push the results to multiselect property.
How to refresh the multiselect property ?
Configure the dynamic layout containing this property to "refresh when property changes".
Evita.
Maantic Inc
Hello Evita,
I had the similar requirement and these steps really helped me. Thank you so much for the suggestion.
Heena
Maantic
AZHAGU DHARSHINI RAJAVEL Swapna Ravula VenkataSruthi Parla Mariem Chebbi Wojciech L
Infosys Limited
How can we save the data using the multiselect list control i.e. the multiple selections need to be captured.
Maantic
It will be saved into the pagelist. Page structure is mentioned in the attached document.
Monisha Elangovan
Cognizant Technology Solutions Philippines Inc.
PH
Thank you, @AVIKMITRA.
