PwC
IT
Problem with VM
Hi everybody,
i have an automation that work on a VMWARE server (w2k12), the runtime is on that server. I'm facing a problem:
I login in a web app (IE), and then i have to donwload a file. When the save bar show, i use send key (%s) to save the file. The problem is that if i have the VM open in RDP the dowload is successful, if the RDP window is minimized doesn't work.
do you have a solution?
tks
Corrado
You can't use Sendkeys on a minimized window, you'd have to use a method to bring the window back up before firing off sendkeys()
