Clover Infotech
Last activity: 28 Mar 2018 2:53 EDT
Running BIX as a stand alone from command line
I want to extract data from database using BIX, We have created extract rules and that is working fine manually by running rule from designer studio,but now our requirement is from command line i have done all configurations required,how to run as a standalone can u suggest me?
Hi Deepak,
You can find the BIX related user guide for your specific version of BIX over here. I can see a section "Stand-alone command-line BIX extractions" in the user guide.
Hope this is what you are looking for.
Regards
Mahesh
Clover Infotech
Hi Mahesh_Midthuru,
I have gone through BIX user guide and i have also done all the file configurations but i am confused in what command i have to use to
run BIX and how to use that command using command line.
Deepak Dhanawade
Clover Infotech
I am getting below error When am trying to run the BIX extract from windows command line .
C:\BIX\Additional_Products\BIX>echo "Bix Ant Seri Start"
C:\BIX\Additional_Products\BIX>call C:\BIX\scripts\bin\ant.bat -f C:\ant -buildf
ile bix.xml
Buildfile: C:\BIX\Additional_Products\BIX\bix.xml
ile bix.xml
Bix:
[echo] Performing Export
[echo] using java version ${javaVersion}
[java] Mar 28, 2018 12:19:49 PM com.pega.pegarules.internal.bootstrap.PRBoo
tstrapDataSource
[java] 1050: Loading bootstrap properties from config/prbootstrap.propertie
s
[java] Mar 28, 2018 12:19:49 PM com.pega.pegarules.internal.bootstrap.Setti
ngReaderJNDI
[java] INFO: Could not find java:comp/env/prbootstrap/ in the local JNDI co
ntext, skipping prconfig setting lookup
ngReaderJNDI
[java] INFO: Could not find prbootstrap in the local JNDI context, skipping
tstrapDataSource
[java] 1050: Bootstrap datatables schema: dataSchema
tstrapDataSource
[java] SEVERE: Unable to connect to database. Will only use properties fro
m file.
[java] java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not
exist
[java]
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:450)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:399)
[java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1017)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:655)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:249)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:566)
[java] at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedSt
atement.java:215)
atement.java:58)
[java] at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4
CPreparedStatement.java:776)
[java] at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(Oracl
eStatement.java:897)
[java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(Oracl
eStatement.java:1034)
[java] at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(Or
aclePreparedStatement.java:3820)
[java] at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(Oracl
ePreparedStatement.java:3867)
[java] at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuer
y(OraclePreparedStatementWrapper.java:1502)
[java] at com.pega.pegarules.configdbcp.dbcp.DelegatingPreparedStatemen
t.executeQuery(DelegatingPreparedStatement.java:99)
[java] at com.pega.pegarules.internal.bootstrap.SettingReaderDB.getAllC
lassificationSettingsDB(SettingReaderDB.java:87)
[java] at com.pega.pegarules.internal.bootstrap.SettingReaderDB.getSett
ingsDB(SettingReaderDB.java:154)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.g
etBootstrapPropertiesFromDB(PRBootstrapDataSource.java:663)
etBootstrapPropertiesFromDB(PRBootstrapDataSource.java:643)
etBootstrapProperties(PRBootstrapDataSource.java:620)
etBootstrapProperties(PRBootstrapDataSource.java:614)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.<clinit>(PR
Bootstrap.java:119)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcces
sorImpl.java:62)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMet
hodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:498)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToP
ega.checkForStartup(AppServerBridgeToPega.java:117)
ega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
ega.invokeMethod(AppServerBridgeToPega.java:273)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java]
tstrapDataSource
[java] 1050: Unable to locate archive.properties properties, setting warVer
sion to -1
tstrap
[java] 1050: Engine schema defined in allclasses: ruleSchema
tstrap
[java] 1050: Engine classes schema: ruleSchema
tstrap
[java] 1050: Assembled classes schema: ruleSchema
tstrap
[java] 1050: prbootstrap.properties merged with prbootstrap entries in Data
-Admin-System-Settings
tstrap
[java] 1050: PRBootstrap.calculateEngineCodeVersionFromDB() - unable to cal
culate codeset version from database: ORA-00942: table or view does not exist
[java]
[java] Mar 28, 2018 12:19:49 PM com.pega.pegarules.internal.bootstrap.PRMin
iLoader
[java] 1050: Will load phase 2 bootstrap from Pega-EngineCode:
[java] Mar 28, 2018 12:19:50 PM com.pega.pegarules.internal.bootstrap.PRMin
iLoader
[java] 1050: PRMiniLoader - unable to load classes from the database: ORA-0
[java]
[java] Mar 28, 2018 12:19:50 PM com.pega.pegarules.internal.bootstrap.PRBoo
tstrap
[java] 1050:
[java] ============ PegaRULES Bootstrap Configuration ============
[java] Date: Wed Mar 28 12:19:50 IST 2018
[java] Java Version: Oracle Corporation 1.8.0_162
[java] Configuration: file:/C:/BIX/Additional_Products/BIX/config/prboots
trap.properties
[java] Pega-EngineCode:
[java] Database: Oracle Oracle Database 11g Enterprise Edition Relea
se Proprietary information hidden.0 - Production
[java] With the Partitioning, OLAP, Data Mining and Real Application Testin
g options
[java] Driver: Oracle JDBC driver Proprietary information hidden.0
[java]
[java] (!) Ignored JNDI Options
[java] (!) Unable to use given database configuration
[java] (!) Unable to locate classes on filesystem
[java] =============== End Bootstrap Configuration ===============
[java]
[java] Unable to load phase 2 bootstrap class: com.pega.pegarules.internal.
bootstrap.phase2.PRBootstrapImpl
tstrap
[java] SEVERE: Error initializing PRAppLoader
[java] java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootst
[java] at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(
PRMiniLoader.java:388)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.loadPhase2B
ootstrapClass(PRBootstrap.java:720)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForSta
rtup(PRBootstrap.java:662)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMetho
dPropagatingThrowable(PRBootstrap.java:408)
ega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
[java]
[java] Mar 28, 2018 12:19:50 PM com.pega.pegarules.boot.internal.extbridge.
[java] SEVERE: Problem during method invocation (main)
[java] java.lang.RuntimeException: PRAppLoader was not properly initialized
, unable to load class com.pega.pegarules.data.internal.access.ExtractImpl
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplemen
tationOf(PRBootstrap.java:208)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PR
Bootstrap.java:324)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(P
RBootstrap.java:304)
dPropagatingThrowable(PRBootstrap.java:409)
[java]
[java] Exception in thread "main" java.lang.RuntimeException: Problem durin
ega.invokeMethod(AppServerBridgeToPega.java:279)
[java] Caused by: java.lang.RuntimeException: PRAppLoader was not properly
initialized, unable to load class com.pega.pegarules.data.internal.access.Extrac
tImpl
Bootstrap.java:324)
[java] ... 1 more
[java] C:\BIX\Additional_Products\BIX\lib\boot\prbootphase2.jar (The system
cannot find the path specified)
[java] Perhaps executing with a non-standard classpath (e.g. JUnit tests)?
BUILD FAILED
C:\BIX\Additional_Products\BIX\bix.xml:16: Java returned: 1
Total time: 2 seconds
"Bix Ant Seri End"
Versions : PRPC - 7.3 , BIX - 7.3.
Deepak
