Aaseya
Last activity: 5 Apr 2018 3:08 EDT
Pagination and Scroll Bar both needed
We have the requirement to show pagination and scroll bar (vertical) both on few eg: Workbasket, search results.
In the Layout properties if we keep it as "Progressive " then we get vertical scroll bar.
And if we keep Page 1 of X or any another then we get Pages but scroll bar is not present in that case.
Please suggest.
Hello Parul,
Please add pixel fix size in the presentation tab of grid layout for height.Height should be less than the content visible, then you will get a vertical scrollbar.
Aaseya
Hello Shibani,
It helped but when we adjust the screen and make it small then scroll bar disappears.
Aaseya
Also I would like to know that if we will fix the height than mostly in mobiles it will not work.
It will be nice to have scroll bars (vertical and horizontal) always. Even if we resize the screen .
Parul
Try to avoid the horizontal scrollbar for the moble, as per the standars UX.
In your skin according to the configuration for the foramts for the Grid i.e the responsive breakpoints configured for the grids ,it will render and also as per the setting on the column of the grid i.e primary ,secondary or other.
Please share the sceenshots for these configurations and also for the issue.
Hello Parul,
Page level Horizontal/vertical scroll auto appears upon screen resize.For Mobile instead of grid use Repeating Dynamic Layout or if still want to use Grid you need to mention primary secondary column .
In mobile Horiontal scroll is not good deisgn as per standrad .
Marcelo Marote
Kindly check below discussion. it may help you.
https://collaborate.pega.com/question/scroll-bar-issue-progessive-pagination
Aaseya
Thanks all.
I tried with selecting in Presentation tab- Fixed size grid and Freeze grid header .It worked for that particular section.
Now I want to have scroll on complete portal. PFA I have highlighted in Red.
