Navigation Tab within a Section
Hi there. How can I build a navigation tab within a section and a section within the tab?
Please refer to the sample in UI gallery.
Thank you. I got them figure out.
can you try using menu .
Below link might help you
https://collaborate.pega.com/discussion/tabbed-navigation-local-action-tabs-disapears
Hi ,
Below link might help you.
http://myknowpega.com/2018/09/09/navigation-rule-pega/
Vinay Reddy
You can also use LIVE UI and and check existing menu and mimic them as per your need.
