Writing VB.net
How can we write VB.net code in Script component in Pega Robotics.
Thanks and regards,
Akash
Thanks and regards,
Akash
VB scripting is no longer supported. You could write a component externally using VB.Net, however.
Hi Jeff,
And how we add a component externally using vb.net.Can You please illustrate this with an example.
Akash
There isn't really an example we could provide since the component is your own code. Just be sure it is of the Type Component. Once you write your component, place it in the installation directory of Studio. On the Toolbox window in Studio, you can right-click and select your component from here and add it to your Toolbox to be added to your automation/global container/etc.... All of your public properties, methods, and events should be available in the Object Explorer window to use like any other component (StringUtils, CredentialStore, etc...).
