Using Interfaces in .NET Components - iTextSharp
I have a question about Interfaces when trying to use iTextSharp (a .NET PDF Library). I have been able to add a reference to it and Choose Items... for the toolbox in Pega Robotics after I edited AssemblyInfo.cs and changed the false to true as in [assembly: ComVisibleAttribute(true)]. But I can't seem to "Add Constructor for Type" for Interfaces declared in itextsharp.dll.
For example, when I click on "Add Constructor for Type" to iTextSharp.text.pdf.parser, I search in vain for ITextExtractionStrategy even though I know it is there because I can see it in the Solution Explorer for iTextSharp which I have easy access to because I had to recompile it as stated previously.
I can get around this by creating a relatively simple script, but really prefer to avoid scripts when I can. Is there some other means by which I can create and use an Interface within Pega Robotics?
