System Management Application (SMA) does not load High Availability Managment page under Administration menu.
Hi, I'm using Pega 7.3.0 and have loaded prsysmgmt. I've configured my 2 clustered nodes. When I click on the links on the left, they load fine but the moment I load High Availability Management, I get the below error and subsequently all the links fail. In the SMA guide (https://pdn.pega.com/products/system-management-application-sma) version 6.3 SP1 (the latest version), there is no mention of High Availability Management under the Administration Chapter. Am I missing out on anything?
MSG:
com.pega.jmx.ui.util.JMXClientException: Node: x.x.x.x Exception: com.pega.jmx.ui.util.JMXClientException:
Stack Trace:
MSG:
Stack Trace:
com.pega.jmx.ui.util.JMXClientException: Node: x.x.x.x Exception: com.pega.jmx.ui.util.JMXClientException: at com.pega.jmx.ui.util.JMXClientException.wrap(JMXClientException.java:49) at com.pega.jmx.ui.action.PerformDefaultOpAction.execute(PerformDefaultOpAction.java:306) at sun.reflect.GeneratedMethodAccessor383.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55) at java.lang.reflect.Method.invoke(Method.java:508) at ognl.OgnlRuntime.invokeMethod(OgnlRuntime.java:892) at ognl.OgnlRuntime.callAppropriateMethod(OgnlRuntime.java:1537) at ognl.ObjectMethodAccessor.callMethod(ObjectMethodAccessor.java:68) at com.opensymphony.xwork2.ognl.accessor.XWorkMethodAccessor.callMethodWithDebugInfo(XWorkMethodAccessor.java:117) at com.opensymphony.xwork2.ognl.accessor.XWorkMethodAccessor.callMethod(XWorkMethodAccessor.java:108) at ognl.OgnlRuntime.callMethod(OgnlRuntime.java:1613) at ognl.ASTMethod.getValueBody(ASTMethod.java:91) at ognl.SimpleNode.evaluateGetValueBody(SimpleNode.java:212) at ognl.SimpleNode.getValue(SimpleNode.java:258) at ognl.Ognl.getValue(Ognl.java:467) at ognl.Ognl.getValue(Ognl.java:431) at com.opensymphony.xwork2.ognl.OgnlUtil$3.execute(OgnlUtil.java:352) at com.opensymphony.xwork2.ognl.OgnlUtil.compileAndExecuteMethod(OgnlUtil.java:404) at com.opensymphony.xwork2.ognl.OgnlUtil.callMethod(OgnlUtil.java:350) at com.opensymphony.xwork2.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:430) at com.opensymphony.xwork2.DefaultActionInvocation.invokeActionOnly(DefaultActionInvocation.java:290) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:251) at org.apache.struts2.interceptor.DeprecationInterceptor.intercept(DeprecationInterceptor.java:41) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at org.apache.struts2.interceptor.debugging.DebuggingInterceptor.intercept(DebuggingInterceptor.java:256) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.DefaultWorkflowInterceptor.doIntercept(DefaultWorkflowInterceptor.java:168) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.validator.ValidationInterceptor.doIntercept(ValidationInterceptor.java:265) at org.apache.struts2.interceptor.validation.AnnotationValidationInterceptor.doIntercept(AnnotationValidationInterceptor.java:76) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.ConversionErrorInterceptor.intercept(ConversionErrorInterceptor.java:138) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.ParametersInterceptor.doIntercept(ParametersInterceptor.java:229) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.ParametersInterceptor.doIntercept(ParametersInterceptor.java:229) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.StaticParametersInterceptor.intercept(StaticParametersInterceptor.java:191) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at org.apache.struts2.interceptor.MultiselectInterceptor.intercept(MultiselectInterceptor.java:73) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at org.apache.struts2.interceptor.DateTextFieldInterceptor.intercept(DateTextFieldInterceptor.java:125) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at org.apache.struts2.interceptor.CheckboxInterceptor.intercept(CheckboxInterceptor.java:91) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at org.apache.struts2.interceptor.FileUploadInterceptor.intercept(FileUploadInterceptor.java:253) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.ModelDrivenInterceptor.intercept(ModelDrivenInterceptor.java:100) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.ScopedModelDrivenInterceptor.intercept(ScopedModelDrivenInterceptor.java:141) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.ChainingInterceptor.intercept(ChainingInterceptor.java:145) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.PrepareInterceptor.doIntercept(PrepareInterceptor.java:171) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.I18nInterceptor.intercept(I18nInterceptor.java:140) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at org.apache.struts2.interceptor.ServletConfigInterceptor.intercept(ServletConfigInterceptor.java:164) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.AliasInterceptor.intercept(AliasInterceptor.java:193) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at com.opensymphony.xwork2.interceptor.ExceptionMappingInterceptor.intercept(ExceptionMappingInterceptor.java:189) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:245) at org.apache.struts2.impl.StrutsActionProxy.execute(StrutsActionProxy.java:54) at org.apache.struts2.dispatcher.Dispatcher.serviceAction(Dispatcher.java:575) at org.apache.struts2.dispatcher.ng.ExecuteOperations.executeAction(ExecuteOperations.java:81) at org.apache.struts2.dispatcher.ng.filter.StrutsPrepareAndExecuteFilter.doFilter(StrutsPrepareAndExecuteFilter.java:99) at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:197) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:90) at com.pega.jmx.ui.action.MultiTenantFilter.doFilter(MultiTenantFilter.java:53) at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:197) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:90) at com.pega.jmx.ui.action.CharsetFilter.doFilter(CharsetFilter.java:59) at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:197) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:90) at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:969) at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1109) at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:4150) at com.ibm.ws.webcontainer.webapp.WebAppImpl.handleRequest(WebAppImpl.java:2208) at com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGroup.java:304) at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:1030) at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817) at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:382) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:465) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:532) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:318) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.ready(HttpInboundLink.java:289) at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.sendToDiscriminators(NewConnectionInitialReadCallback.java:214) at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.complete(NewConnectionInitialReadCallback.java:113) at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) at com.ibm.io.async.AsyncChannelFuture$1.run(AsyncChannelFuture.java:205) at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1909)
