Deloitte
How to Configure the Pega Robotic Studio With Pega After Installing in Personal Machine
Can any one tell me the Steps to integrate the Pega with Pega Robotic Studio.
RuntimeConfig.xml
<Robotics>
<!-- LocalApiService tag is specific to RDA. -->
<!-- enabled: If true, the Runtime will self host a REST service to accept requests from the Pega application. -->
<!-- SSL: If true, the service uses SSL and must be accessed via https. -->
<!-- port: Port the service will listen on. -->
<!-- allowedOrigins: Comma delimited list of domains that the service will accept requests from. -->
<!-- A specific domain can be given (i.e. acme.pega.com) or the subdomain may be wildcarded (i.e. *.pega.com) -->
<!-- Requests from any domain not in this list will be rejected. -->
<!-- JWTSecurity: If true, enhanced security is enabled that required signed JWT tokens with every RDA request to Runtime -->
<!-- PegaServerURL : If JWT Security is enabled, this URL is used to retrieve the JWT profile public key used to validate RDA requests -->
<LocalApiService enabled="true" SSL="true" port="9443" allowedOrigins="*.pega.com" JWTSecurity="false" PegaServerURL="https://MyPegaServer.com/RobotMgr" />
<!-- PackageServer baseUrl: Address of the Package Server API endpoint. -->
<PackageServer baseUrl="http://MyPackageServer.com" />
</Robotics>
StudioConfig.xml
RuntimeConfig.xml
<Robotics>
</Robotics>
StudioConfig.xml
<!-- This section specifies settings for Studio connect to the Pega server to retrieve class names and field information. -->
<Robotics>
<!-- baseUrl: Address of Pega API endpoint -->
<PegaServer baseUrl="https://<subdomain>.pegacloud.com/prweb/api/v1/" />
</Robotics>
please suggest the modifications in the above attributes if needed.
my pega in also in Local machine.
