Pega Mashup
Is there any way to get the reporting can be used in mashup?
Any way to generate the meshup code for the pega Reporting ?
  I was able to achieve portal using the harness configuration in mashup. (PORTALS)
Chandan U
  Hello Chandan,
You can configure the harness with required report definitions, then create the mashup code for that harness. Now you can embed that gadget in your external application.
Praveen
Chandan U
