Maantic Inc
Maantic Inc
Maantic Inc
Posted: May 21, 2018
Last activity: May 25, 2018
Last activity: 25 May 2018 8:49 EDT
Pega Mashup in Angular Portal
Hi, we are planning to display pega mashup screens in angular portal.
Recently anybody tried this combination? if yes , How is pega mashup code called in angular code?
I am good with Mashup but not a lot of experience with angular portals. This isn't getting a lot of responses so though I would see if we could get you started.
A Mashup requires you to define a <script> tag for getting the Mashup scripting and <DIV> element containing definition of the Mashup.
I would think you would want to create a angular component for each Mashup and then add the <script> reference and <DIV> content to component.html.
Component: mashup-createNewWork
mashup-createNewWork.component.html:
<script src ='https://[PRPC_HOST]/prweb/PRServlet?pyActivity=pzIncludeMashupScripts&disableCompacting=true'></script>
<div id='testNewWork' style="overflow:auto" data-pega-gadgetname ='GadgetTestNewWork'
data-pega-action ='createNewWork'
data-pega-action-param-classname ='PegaSample-Task'
data-pega-action-param-flowname ='BasicProcess'
data-pega-action-param-model =''
data-pega-isdeferloaded ='false'
data-pega-applicationname ='[APPNAME]'
data-pega-threadname ='STANDARD'
data-pega-systemid ='pega'
data-pega-resizetype ='stretch'
data-pega-action-param-parameters=""
data-pega-url ='http://[PRPC_HOST]/prweb/IAC'>
</div>
The template part of the component could also be used to specify the div instead of using the component.html.
</div>
Does this get you started?
